  1. I have a Sony DRU-500AX (version 2.0c) and I typically use Printable Ritek G04's. My buddy bought BeAll 4X printables that print almost all of the way to the center (very cool), the only problem I have is that my Sony won't burn them at 4X without errors.
    Are there any other 4X capable brands that print to the center like BeAll's?
  2. Unfortunately not that I have found.
  3. Hi,
    I have the same burner, same firmware and I burn the same discs /from Meriline/ at 4x without any problem so far. Could it be that your computer is not set properly or something? Let us know!
  4. Originally Posted by Turtle49
    You can try this place www.blankmedia.ca after some taking with the owner we were able to get him to bring in some full IJP, the price is very good, however they are light purple dye.
    But again for the price its low enough to give them a try. If you want him to carry ritek full IJP post a comment in the forums, if there is enough response he may listen.
    autorf
  5. Thanks for your responses.
    Hi,
    I'm running a pretty fast system and I burn Ritek G04's at 4X all the time without issue. I may have got a poor run or something but to be honest after burning 4 and having them have errors I decided 2X would be fine.
    The BeAll's are a decent product, they've played on everything i've tried. The weird part is that they didn't error during the burn, they would just pause during play back for no appearant reason. When I burned them at 2X they would play fine.
    autorf
    Thanks I'll keep an eye on this site. And i would definetely be interested in full printable Ritek G04's.
