I know Canon is known for there lenses. Does anyone know if the lens they use in the Optura 10/20 is of true Canon quality ? It is a bit on the small side - only 37mm.
I don't have an Optura, or any other Canon models. I've heard they're okay in good light. But the problem is that all Canon consumer models perform very poorly in low light. I like the 16X optical zoom on Optura 20 though.
If I were to buy a camcorder today, I'd take a good look at Panasonic GS70. It's got 3 CCDs and acceptable low light performance. And, it's in the same price range as Optura 20.
Take a look at the reviews on camcorderinfo.com. -
I have owned an Optura 20 for approximately 8 months now. I purchased it to replace a Canon Hi-8 model 8100. I have been very pleased with it for most uses. The lens is typical Canon quality. The only things I did not like about the lens is it’s limited wide angle, but that was solved with the purchase of an inexpensive wide angle adaptor. I was somewhat disappointed in it’s low light performance, but it has enough other features that I can live with that.
What is a good DVD player lens cleaner?
By Puppets86 in forum DVD & Blu-ray PlayersReplies: 15Last Post: 26th Jun 2013, 19:35 -
Canon 250D or 500D Macro Lens for XF100?
By Compo in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 11th Apr 2012, 14:55 -
Canon T3i Any Good?
By budwzr in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 24Last Post: 11th Dec 2011, 10:22 -
Protecting Canon XM2/GL2 Lens
By foxbox in forum Newbie / General discussionsReplies: 0Last Post: 19th May 2008, 08:48
