I am confused again thought I had this concept understood but not sure.
I am encoding in Divx from an MPEG2 encoding of a TV program captured using the PVR-250 and is captured at a resolution of 480x480 and some are 640x480 and play back on the TV with the correct aspect ratio using Mythtv (using linux). Mostly I have done DVD 720X480 conversion using Gordian Knott. I never realized that when I encode with GK that when I set the resolution I typically used 512x272 and that maintained the 4:3 aspect ratio.
Here is what I am confused on. Again![]()
For playback on a TV I thought I wanted interlaced encodings for best picture and that required a resolution of ### x 480. But when I capture interlaced MPEG2 at 640x480 or 480x480 and then encode to 512x272 or 480x256 I maintain the 4:3 aspect ratio but do I loose the interlace?
If I do in fact loose the interlacing do I now just have a progressive scan version and the encoder (transcode in my case) deinterlaced while encoding (I did not tell transcode to use a deinterlace filter).
Appreciate the help in understanding this.
Results 1 to 1 of 1
Reconverting Divx videos to smaller Divx files.. strange resolution
By arcooke in forum Video ConversionReplies: 2Last Post: 19th Jul 2011, 03:35 -
Confused! Confused! Confused! VCR to DVD; major question Toshiba Diomage SV
By CAnn12 in forum Capturing and VCRReplies: 0Last Post: 5th Feb 2011, 12:26 -
confused with divx files that work
By ceve4life in forum Authoring (DVD)Replies: 3Last Post: 30th Jul 2008, 17:42 -
deciding on the correct resolution setting when converting to mpeg2
By Dreadnaught in forum Video ConversionReplies: 4Last Post: 15th Jan 2008, 09:36 -
Confused about monitor resolution
By edong in forum ComputerReplies: 10Last Post: 2nd Jun 2007, 16:41
