Could anyone help me to burn these files to DVD with the simplest method posible, I have been creating a few DVD's with VCD easy enough with Tmp Dvd author, but when I go to put an svcd through there it says its too big resolution and will not go any further.
I have been told svcdtodvd is an easy program but then you have to install besweet as well, all sounds a bit complex if you ask me, and Im just a newbie at Dvd writing and creating.
Any help from you guys would be great.
Soulkiss![]()
http://www.mediachance.com/dvdlab/tutorial/svcd.html
if you want to use tmpgenc dvd author you must use dvdpatcher. -
Thanks Baldrick, I will try this, I just need to know what I do with the DVD patcher now lol, What are the settings for a standard dvd ??...........Soulkiss
Am I the only one getting these odd little jagged edges on the converted video? I've used svcd2dvdmpg and dvdlab with the same results. Is it because no one cares that their converted svcds look like crap?
Help with svcd 2 dvd
By tastybaker in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 11th Aug 2010, 10:30 -
Svcd 2 dvd
By GeordieDave in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 8th Feb 2010, 11:05 -
VCD to DVD (not SVCD)
By noyou in forum SVCD2DVD & VOB2MPGReplies: 20Last Post: 19th May 2009, 17:56 -
Can a SVCD video file be burned on to a DVD and played in a DVD player?
By dvdnewbie64 in forum Newbie / General discussionsReplies: 9Last Post: 17th Apr 2008, 21:44 -
How to burn a SVCD onto a DVD?
By php111 in forum Authoring (VCD/SVCD)Replies: 9Last Post: 16th Oct 2007, 03:32
