Hey buddies...
I'm new to the DVD concept...funny...but fine..
Ok...
now my serious problem is dat the terms in the softwares I'm using, boggles me
...hee hehee..anyways
Getting back to buisness..
the scene is dat I have a MAC & OSEx...& DVD2oneX...
I'm not sure bout the ver's...but I scored it like a week before of still trying to copy a DVD....
What I need t know r the exact settings on OSEx & thenDVD2oneX to copy a 12gig DVD or any above 4.5Gb...
to probably 3 or as many blank DVD it might take...I dont think we might need too much...sorry..
I have made a DISC IMAGE with Toast...& I have to mount the Image before I start OSEx so it recognises the disc.....
I have read that the ideal settings is to leave it to DVD folders...anyways... I have tried all the options I can possibly figure...but after all I try...
when I load the VOB_TS in DVD2oneX it gives me the message dat it cannot proceed coz the data is not decrypted...
If I can get some help on how I can split these volumes peacefully...
into more mediums...& also if there is a way to restore the Xtra scene's ,menues...will b like the ultimate setting...
thanx a ton...![]()
1. check my website, tutorials just for you
easy ones. The link is in my signature
2. dont use OSeX unless you have to because dvdbackup is much easier.
again, its all spelled out in my website.
Click on DVD to DVDr
and use the Beginners tutorial.
I still have to update it a bit, but the general concepts are the same!
if you have problems, feel free to post back here.
Galactica
Portable Decrypting Software
By Drazick in forum DVD RippingReplies: 4Last Post: 20th Aug 2010, 18:11 -
DVD Decrypting Question?
By daz1976 in forum DVD RippingReplies: 5Last Post: 14th Jan 2010, 16:44 -
decrypting a dvd with MTR 2.6.6
By andyx181x in forum MacReplies: 11Last Post: 2nd Dec 2007, 10:05 -
Errors decrypting dvd
By Beaker14 in forum Newbie / General discussionsReplies: 2Last Post: 31st Oct 2007, 11:59 -
Decrypting Software
By csaplot in forum Video ConversionReplies: 1Last Post: 22nd Jul 2007, 10:54
