I am almost done with my VCD menu, which I've made in nero vision express, but I realised you can't make a movie clip intro lead into the menu with this program. So I looked it up on this site and discovered you can do this on VCDeasy. I was hoping maybe though, that I could import my nerovision menu to VCDeasy so that I don't have to recreate the whole damn thing in a new program? Is there anyway to do this? I just want my intro and then I can sleep easy....
-jam tomorrow, jam yesterday, but never ever jam today...()_()
=(6.9)= -
For what you want to do, the easiest way is to make an image of your VCD with Nero first (i.e., into the .NRG format).
Then use the lkVCDxRIP tool ( in VCDImager Tools GUI ) to extract the image back into its components with the XML descriptor file.
At this stage, you can easily put in additional content and for what you want to do (i.e., an opening animation) is trivial... trivial that is, if you know what you are doing...
I suggest having a look at http://www.michaeltam.com to learn about how the underlying VCDImager XML system works.
If you can't work it out, post the XML file and I'll show you how to edit it to put in the additional animation.
In any case, once you've finished editing your VCD structure, you can rebuild it again with lkVCDxBUILD (again, part of VCDImager Tools GUI ).
Then, you can burn the image onto CD-R for the physical disc.
Best regards.Michael Tam
w: Morsels of Evidence
Creating Animated Menu images
By DesertAvenger in forum Authoring (DVD)Replies: 4Last Post: 15th Sep 2009, 23:30 -
Deconstructing, translating, then reconstructing an animated menu
By ArtOfLosingMFZB in forum Newbie / General discussionsReplies: 1Last Post: 6th Mar 2009, 17:06 -
GUI for dvdauthor Animated Menu Buttons
By deco81 in forum Authoring (DVD)Replies: 3Last Post: 6th Dec 2008, 18:41 -
animated menu w/ ConvertXtoDVD
By WhiteKenny in forum Authoring (DVD)Replies: 2Last Post: 2nd Aug 2008, 15:13 -
Need to add intro video before menu on several finished DVDs
By benracin in forum EditingReplies: 1Last Post: 1st Oct 2007, 11:29
