Hi I have a movie which is encoded with Divx, and it has a second languge translating the english. I would like to remove this second language. I've ripped the audio to wav format, and have tried with a couple of applications. So far I havent had any luck, and i couldnt find a guide on this site, and forum. Does anybody have any ideas?
Gr33nJ3lly
Open the divx in virtualdub
Select video->direct stream
Select audio->wav audio and open the wav
Select audio->full processing
Select audio->compression mp3
Select file->save as a new avi
Done.
You could also rip the mp3 track from the divx and use it in virtualdub and you don't need to reconvert it again then. -
Im sorry, i must have not been as clear as i thought i was. What im trying to do is remove the second language from the wav file, and leave the rest of the audio intact.
Thank you for your speedy reply just the same :d
Gr33nJ3lly
Removing artifacts
By IsAB in forum EditingReplies: 6Last Post: 15th Feb 2011, 03:24 -
Removing artifacts
By IsAB in forum Newbie / General discussionsReplies: 1Last Post: 13th Feb 2011, 10:51 -
Removing sub from mkv
By vbd in forum Video ConversionReplies: 1Last Post: 27th Apr 2010, 13:27 -
removing logo
By LukeGuldan in forum EditingReplies: 1Last Post: 20th Nov 2009, 00:42 -
Removing DivX watermark w/Vista Codecs pack
By Grunberg in forum Newbie / General discussionsReplies: 0Last Post: 10th Nov 2007, 09:12
