How can I extract the sound from a DVD?
Example:
DVD of music show (like Queens, Michael Jackson, etc...)
I would like to extract some musics from it, how?
Thanks,
The December 2003 issue of MacAddict has a good description of this process on pages 70 and 71. They use OSEx to rip the audio from the DVD and mAC3dec to convert the AC3 audio to 48 khz AIFF.
I suppose you're talking about a normal DVD movie of a live concert or something like that.
I would do it the normal way. Rip with DVD Decrypter, De-Multiplex with TMPGEnc, then do whatever I wanted to with the audio files.
Pretty simple process like that.
Good luck. -
Sometimes the PC folks wander into this forum and look around with a lost and bewildered look. They say gibberish like TMPGEnc and DVD Decrypter and then shuffle away to post in the linux forum. The previous post is spot on. OSEx to rip as elementary streams then MAC3Dec to take the AC3 and turn it into a cd ready 48 kHz AIFF.
For a step-by-step guide go to http://forums.macrumors.com/showthread.php?s=&threadid=52847.
Software for extracting clips from DVD
By gaurav200x in forum EditingReplies: 2Last Post: 10th Aug 2010, 14:43 -
Extracting parts of a DVD
By jabbo5150 in forum MacReplies: 9Last Post: 1st Jun 2009, 00:50 -
Extracting subtitle from DVD
By gameroftheuk in forum Newbie / General discussionsReplies: 1Last Post: 4th Aug 2008, 17:09 -
Finding and extracting single sound
By Nator in forum AudioReplies: 1Last Post: 25th Jun 2008, 04:27 -
Extracting DVD menu and re-using them?
By zhiwei1710 in forum Authoring (DVD)Replies: 2Last Post: 17th Feb 2008, 07:52
