I'm looking to find a good program to put menus on my VCD's. I have Nero, but the menus it has are kind of simple, and I'd like to be able to customize them a little more. Like I'd like to be able to have a main menu, and then choose an item, and have another menu come up with a couple more choices. Also, I'd like to be able to really specify where on the menu the items will appear.
Anybody have any suggestions? Something fairly easy to use would be super....
Thanks for any input!!!
Results 1 to 9 of 9
Here's a good guide for menu creation with it as well ...
https://www.videohelp.com/forum/userguides/104503.php -
Have a closer look at VCDEasy.
If you don't want to buy anything, then get the last freeware version of VCDEasy (version 1.1.5.2).
VCDEasy is a GUI to VCDImager, so if you want to learn how the underlying system works, I suggest have a look at here: http://www.michaeltam.com
Regards.Michael Tam
w: Morsels of Evidence -
I played with VCDEasy some more, and it looks like it wouldn't be too bad, but I can't get it to burn. I get through the whole thing, and it makes the BIN/CUE File, but I don't know how to burn. I found a guide that said how to burn using VCDEasy, but it didn't work for me, I just got an error about one of my drivers possibly being not up to date.
Is there any program that makes vcd menus similar to DVD menus, like where you can move your selection up and down with your dvd remote, and it kind of highlights or underlines the text as you are on it? Or do all VCD menus require you to select a number to select which clip you want to watch?
I really appreciate all your help!
If you've got the BIN/CUE files, all you need to do is burn using Nero. The BIN/CUE files are CD IMAGES -- ready to burn.
If Nero --
1. Load Nero
2. Close Wizard
3. Click on FILE (top left corner)
4. Select BURN IMAGE
5. Browse to where the BIN/CUE file is located
6. Select the CUE file
7. Click on WRITE
If Nero Express --
1. Load Nero Express
2. Select DISC IMAGE OR SAVED PROJECT
3. Change FILE TYPE to IMAGE FILES (*.NRG, *.ISO,*.CUE)
4. Browse to where the BIN/CUE file is located.
5. Select the CUE file
6. Click on NEXT
That's it for Nero !! The BIN/CUE files are already authored and are actually IMAGES. All you need to do is burn them to CD. -
It worked! THanks so much! I tryed it on a cd-rw and it's going to work perfect. Now that I know how to do this, as soon as I can get my mpeg videos just how I want them, I can burn and be done!
Thanks again. This site is the best!
What Program was used to create these menus?
By BIGD22 in forum Authoring (DVD)Replies: 14Last Post: 21st Nov 2011, 18:43 -
help required on making simple but 'deep' dvd menus
By lancealittle in forum Newbie / General discussionsReplies: 9Last Post: 18th Sep 2010, 06:34 -
A program for JUST making custom DVD video menus?
By gom in forum EditingReplies: 6Last Post: 23rd Oct 2009, 04:05 -
Program that allows direct VOB burning AND menus
By 6079 in forum Authoring (DVD)Replies: 8Last Post: 22nd Jul 2009, 05:15 -
making custom dvds (program)
By tk187 in forum Authoring (DVD)Replies: 9Last Post: 4th Sep 2007, 08:41
