How can you burn a video (Mpg) bigger the 4.7 gigs to one disc . What tools or programs need?
You can't,the actual size of a DVD-R is 4.37GB's. You could try converting your files to mode 2 but they probably wouldn't play. If you get mode 2 to work you could get 5GB's.
If the mpg file is allready DVD compliant you can just author a DVD with Tmpgenc DVD Author (or some other program) and then shrink it to fit on a DVD with DVDshrink.
(I've never heard of mode 2) -
Look in the tools section "Mode2CDMaker". It creates an image file which can be burned in mode 2. Mode 2 works by not recording data check bits,that's why you can burn 800MB VCD/SVCD on a 700MB CDR. VCD/SVCD are burned in mode 2 by default.
I've used Mode2CDMaker to make 800MB miniDVD's but they won't play on most DVD players that support miniDVD.
Blu Ray and burning a Data Disc...not a Video Disc
By Moontrash in forum DVD & Blu-ray WritersReplies: 16Last Post: 16th Dec 2019, 23:18 -
LCD Monitor Screen Size, bigger isn't really bigger?
By Des in forum ComputerReplies: 13Last Post: 27th Dec 2011, 15:13 -
VIDEO_TS folder shows much bigger than disc itself
By marke0828 in forum DVD RippingReplies: 3Last Post: 26th Jul 2011, 18:38 -
DVD shows me 750 gigs????
By lj5 in forum DVD RippingReplies: 10Last Post: 5th Feb 2010, 04:02 -
After burning, DVD disc was changed to CD
By coody in forum ComputerReplies: 0Last Post: 22nd Sep 2009, 22:16
