Should I send my newly bought DVD+RW recorder back for a DVD-R recorder or one that supports both??
Steve
depending on what your trying to do, but i'd get a dual format writer dude, so u can make ur own opinions cuz u'll get a lotta different answers starting a thread with that name.
josh -
I believe you will find the DVD-R has the greater compatibility across DVD players, although it is not 100% (more like 85-90%) while DVD+R falls into the 80-85% range. Most new players will accomodate either, however. 10-15% of players will not play any "R"ecordable media reliably.
IMHO -- the absolute best bet is to get a dual mode burner as different players will sometimes have a preference of 1 over the other. If you will be recording for mutliple players (yours, friends and family), the flexibility to record to everyones requirements can't be beat. -
Most new standalone DVD players 'should' be able to accept either a DVD-R or a DVD+R (pretty much anything made in the last two years). If you are making them for yourself, try burning a disc and see what happens. If you are making DVD's for other people (e.g. converting home movies or something like that) then it is best to get a dual format burner.
As to which format is better.....its like saying "What is better, Apples or Oranges?".......some like apples, some like oranges and some don't care."Weekends don't count unless you spend them doing something completely pointless."
Bartman 8) -
I appreciate everyones response,Im sending my DVD+R recorder back to Dell and just purchased a Dual Recorder,hope it fixes my probs
again
Steve
DVD Recorders and copyrighted TV
By InXess in forum DVD & Blu-ray RecordersReplies: 27Last Post: 23rd Oct 2010, 14:26 -
Which VCR and DVD Recorders?
By Canes in forum DVD & Blu-ray RecordersReplies: 26Last Post: 11th May 2010, 21:48 -
DVD Recorders
By Dragoan in forum DVD & Blu-ray RecordersReplies: 4Last Post: 19th Mar 2010, 12:19 -
Stand alone recorders; more of a problem than PC recorders?
By videobruce in forum DVD & Blu-ray RecordersReplies: 24Last Post: 13th Nov 2009, 12:27 -
Any new JVC DVD Recorders out there?
By MeekloBraca in forum DVD & Blu-ray RecordersReplies: 2Last Post: 12th Feb 2008, 14:24
