Hi ! Guys I have been work on svcd on cdrw so when I test play on my dvd player look good picture but motion skip alot and freeze and play and freeze so mean that what can I chance to improve? And other quesion is svcd should playable on most all dvd player?
Thank
try lowering the bitrate some. you might be choking the player (feeding it more data than it can process)
Hi ! I use DV camcorder sony transfer to pc as 1394 on capture video on three software. What better software for convert to mpeg2 I am going try TMPEGnc to see if solve .
I know I will learn alot of different way to write on cd so when I use vcd work good most time but I like svcd look great than vcd that why. Thank for helping. SO I will keep post this if I have problem. For burning cd I like nero is better than Adptec easy cd. Correct if I am wrong I just learn everyday LOL.
try an average bitrate of about ~2100 kbps. most players that play SVCD will handle that with no problems, and that should keep peaks below 2500kbps, a threshold for some players
Always use an external encoder. For SVCD, use CBR 2500. You won't save that much room with VBR (assuming the encoder does a good job on the VBR) but it'll take a lot longer.
Get a Pioneer DV-343 dvd player. I recommend this one because it plays ANY SVCDs I throw at it. Diffrent and odd bitrates play fine. If your model screws up or doesn't do what mine has been doing for the past month, I would return it.
And thats my 2 cents.
<font size=-1>[ This Message was edited by: jdcruisin on 2001-07-11 17:30:40 ]</font>
MKV DvdRip Xvid Downloads Play on WMP but wont play on my PVR
By dashas in forum Newbie / General discussionsReplies: 7Last Post: 25th May 2011, 06:15 -
my panasonic standalone dvd can't play pal dvds...but can play pal svcd's
By stoico1 in forum Newbie / General discussionsReplies: 0Last Post: 9th Sep 2009, 17:46 -
Does Toshiba HD-A2 play SVCD's?
By desertfox in forum DVD & Blu-ray PlayersReplies: 3Last Post: 20th Aug 2007, 10:40 -
how to play seamless loop svcd's
By markwest in forum Authoring (VCD/SVCD)Replies: 8Last Post: 11th Aug 2007, 15:06 -
Help with PAL SVCD to NTSC SVCD
By silentmonolith in forum Newbie / General discussionsReplies: 4Last Post: 6th Jul 2007, 07:18
