Is there anything I should know right out of the box for this unit? Any updates, firmware, etc? I have the latest versions of dvd shrink and nero and am ready to get going...hoping that I will be able to burn DVD-R's for my old Toshiba SD 1600 and my Phillips DVD 724.
Since I am totally new to all of this I am hoping for some good advice. Thanks in advance!
OMIT NEEDLESS WORDS!
I would go to www.rpc1.org and update the firmware.As for your "old" DVD Players I would first check over in "DVD Players" for -R/+R compatibility and test with a DVDRW and see if they will play .mp2 audio,if not then you will have to use AC3 or LPCM.If you have problems with -R there is a new booktype tool for +R located in "Tools'
A bitsetting tool too...
http://club.cdfreaks.com/showthread.php?s=&threadid=82927
Installed latest Ripbot264, says Java is not installed, even though it is
By fatcharlie in forum Newbie / General discussionsReplies: 3Last Post: 13th Dec 2011, 10:44 -
New Lite-on drive being recognized as old lite-on drive
By tlrbjc in forum DVD & Blu-ray WritersReplies: 2Last Post: 23rd Jun 2010, 09:21 -
The same OS installed on two disks
By Jomapil in forum ComputerReplies: 29Last Post: 4th Jun 2009, 16:35 -
Just installed and failed
By cantthinkofanickname in forum Newbie / General discussionsReplies: 12Last Post: 21st May 2008, 13:20 -
Why do programs need to be installed?
By Rudyard in forum ComputerReplies: 18Last Post: 18th Jun 2007, 10:00
