hi,
is it possible to fit more than 80 minutes on a 700mb/80 minute audio cd? i tried decreasing the frequency range and it halved the file size, but i still can only get 80 minutes on the cd. or are audio cd's fixed at 80 minutes? thanks.
You cannot change the "bitrate" of an audio CD. It is dead set at a particular setting. You can change it of course... but it won't sound right on a CD player afterwards though.
To burn more than 80 minutes, you need a CD burner that can overburn. You can generally overburn by at least one minute on most CD media fairly safely.
If you want more than that, then you will need to buy 90 or 99 minute CD-R discs.
Regards.Michael Tam
w: Morsels of Evidence
Fitting more onto a DVD
By Woolen Llama in forum Authoring (DVD)Replies: 14Last Post: 23rd Sep 2010, 07:31 -
VCD to PSP - Audio out of sync in last five minutes
By BozQ in forum Video ConversionReplies: 6Last Post: 2nd Apr 2009, 23:43 -
Fitting more in the dvd
By btkuehn in forum Newbie / General discussionsReplies: 2Last Post: 17th Nov 2008, 17:53 -
Help Fitting Videos on CD...
By skinnerback in forum Video ConversionReplies: 4Last Post: 4th Sep 2007, 17:12 -
fitting more than 1 film on a dvd - help!
By welshgal in forum Newbie / General discussionsReplies: 5Last Post: 5th Jul 2007, 13:16
