Results 1 to 9 of 9
  1. Hi all,
    I'm not sure if this is the right "section" in the forum to post cause i'm a newbie! but plz I really need help!
    can anyone please give me all the steps (but with your instructions not to figure out myself what to do) and softwares to burn an AVI to a one recordable DVD?! really important! (but it has to fit into the DVD-R)..
    thx alot.
    pupik!
  2. oh and btw it would be better off if you give me a software that turns the avi into the VIDEO_TS folders and stuff... oh and i really need to do some authoring and like "scene selections" so it would really help! and it would be great if it would all be on one software and as simple as it gets.. 8) thx!!!
  3. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    Nobody will give you all the steps in one post, it's far to complicated and there's many ways of doing it. Basically you need to convert your avi to DVD compliant mpeg then author and burn. The guides section has all the detailed instructions, step by step. Try here.
  4. Originally Posted by ZippyP.
    alright thx alot anyway
  5. but wait!
    will the program "Video Studio 7" do all of those??
    and if so can you plz give me a link ro a guide for it!
  6. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
  7. I am a newbie to this forum, but I have been researching this since 02/01/03 and this is what I came up with. I use Honestech MPEG Encoder 5.0 to encode any file to DVD Format. It does the Audio and Video for you, very easy tool. You can get this at Honestechnology.com for $49.00. Then I use TMPGEnc DVD Author or DVD X Maker to do the authoring and burning to DVD. I like the DVD X Maker the best. The step by step wizard makes it real easy. Both are excellent programs though. They make excellent DVD's. Hope this helps you. Oh you can find a link for these last too programs in the tools section on this site.
  8. Renegade gll99's Avatar
    May 2002
    Canadian Tundra
    The closest thing to an avi to dvd with simple menu creation that I know is called NEODVD.
    The create function will let you input an avi, create simple menus, place chapter points, create the DVD folders and let you write them to your HD or to your writer.
    They used to have a demo up to version 4 but I think it's now only payware.
    I'm not saying it's the best (or not) but it's as easy as it gets.
  9. ok thx alot to all of you guys!!
    this forum is the best!
