I have been making svcds for about a year now. I have decided that now is the time to buy a dvd burnner. Mostly, I want to backup my collection of dvds and transfer my home movies onto dvds. I am not looking to back up my hard drives or anything else. However, I have been searching for a dvd burner and keep hearing about DVD+RW and DVD-RW. What is the difference between the two? Which would be better suited for my needs? Or should I purchase a drive that will burn both?
Thank you for your help.
I would base your decision to buy on this data:
DVD-R and DVD-RW
DVD-R/W was the first DVD recording format released that was compatible with standalone DVD Players.
DVD-R is a non-rewriteable format and it is compatible with about 92% of all DVD Players and most DVD-ROMs.
DVD-RW is a rewriteable format and it is compatible with about 75% of all DVD Players and most DVD-ROMs.
DVD-R/W supports single side 4.7 GB* DVDs(called DVD-5) and double side 9.4 GB* DVDs(called DVD-10).
These formats are supported by DVDForum.
DVD+R and DVD+RW
DVD+R/W has some "better" features than DVD-R/W such as lossless linking and both CAV and CLV writing.
DVD+R is a non-rewritable format and it is compatible with about 86% of all DVD Players and most DVD-ROMs.
DVD+RW is a rewritable format and is compatible with about 75% of all DVD Players and most DVD-ROMs.
DVD+R/W supports single side 4.7 GB* DVDs(called DVD-5) and double side 9.4 GB* DVDs(called DVD-10).
These formats are supported by the DVD+RW Alliance.Hello. -
Buy some dual drive & you will see what suit you best (i mean +, - (dash)format)...
What is the Best DVD Duplicator to Buy?
By powerguy in forum Newbie / General discussionsReplies: 3Last Post: 18th May 2011, 10:35 -
burnner program
By brenjim in forum Video ConversionReplies: 1Last Post: 1st Mar 2009, 12:06 -
Best Buy dvd player
By golfer in forum DVD & Blu-ray PlayersReplies: 7Last Post: 21st Feb 2009, 14:59 -
Should I buy DVD-R with no brand name?
By greglee in forum MediaReplies: 6Last Post: 16th Aug 2008, 01:49 -
SVCD2DVD To buy or Not to buy?
By enjohn49 in forum SVCD2DVD & VOB2MPGReplies: 7Last Post: 21st Mar 2008, 11:55
