I'm trying to convert an avi recorded at 23,976 fps to SVCD mpg, playable on a PAL tv set. I have tried using PAL and NTSC or NTSC Film templates (using TMPGe) I've tried using the 3:2 drop down feature but, when I try and burn with nero, it states its' not in SVCD format. Even if I de-select 3:2 and go with interlace or non-interlace, no joy. Can anyone point me in the right direction.
Here is how you do it PROERLY! here is my SVCD Template
members.tripod.com/ehhhe_douglesh/yeshi_templates2.zip
Put them in your TEMPLATE directory, and load the NTSC Film template and encode, and it should work it fine.
<font size=-1>[ This Message was edited by: Yeshi on 2001-10-15 20:03:34 ]</font>
<font size=-1>[ This Message was edited by: Yeshi on 2001-10-15 20:04:10 ]</font> -
Your not doing anything wrong. Nero doesnt recognize the pulldown flag and says your mpg is non compliant when it really is. Try burning it anyway and seeing if it will play. Most pal tv's have no trouble playing an ntsc signal, for the ones that do most dvd players have no problem modifying the ntsc signal to play on a pal set.
If you do have problems you will have to telecine that mpg to pal. You can use TMPGenc to do this but most likey you wont need. -
Converting 23.97 to 25 fps is a seriously not cool thing to do in TMPG. On the off chance that you have to convert it, use Vdub or something to do it beforehand and frameserve it.
Also, Nero has no problems with pulldown flags as long as you're using NTSC resolutions. If you've converted it to PAL resolution with NTSC framerate, it's technically noncompliant. -
23.976fps is a compliant ntsc resolution as long as the pulldown flags are there, yet Nero still complains about the fps being non-compliant, at least it has every single time I have tried it and I have heard the same thing from numerous people. So as far as I can tell Nero definitely has a bug about this.
Yep. same deal over here, but it doesnt worry, if you jsut burn it anway, it still works, and plays back at 29.97 FPS (I THINK).
25 PAL to 23.976 NTSC AVI
By Nedward Orton in forum Video ConversionReplies: 8Last Post: 24th Mar 2012, 10:56 -
Convert 29,976 (NTSC) to 25,000 (Pal) AVI
By volker028 in forum Video ConversionReplies: 5Last Post: 23rd Mar 2012, 03:00 -
Prolem with 23.976 FPS AVI file
By ho1 in forum Video ConversionReplies: 3Last Post: 22nd Oct 2009, 12:50 -
Jitters with 23.976 AVI need opionions..
By funkymix in forum Video ConversionReplies: 8Last Post: 5th Apr 2009, 17:36 -
Difference?? 23,976 pics/s or 29,976 fps
By twanbaten in forum Authoring (DVD)Replies: 1Last Post: 6th Nov 2007, 12:29
