Hi
I have completed the turotrial at https://www.videohelp.com/divxtovcd.htm#audio. I not have my mpg file ready to burn to a CD. But I would like to burn it to a DVD+R using Nero rather than a CDR. Even tho I have selected Video CD in the New Compilation Window, when I come to burn my DVDR Nero tells me that there is no Media in the drive (even tho there is a new disk in the drive. I have selected the correct recorder (I have two CDR's in my tower).
Must I do something different to burn my mpg's to dvdr in Nero?
Cyberdood
So is there no way to get my download mpg file on to a DVDR disk at all?
Originally Posted by Baldrick -
You could burn your mpg as a simple data file. The problem with that is many DVD players won't play it. Raw mpg playback poorly supported by DVD players. You would be better off to author your mpg into a DVD compatible set of files then any DVD player will play it.
OK thanks for that.
Is there a tutorial to do what you suggest?
Originally Posted by wulf109
Burning MPG and DIVX to a DVD
By OldGuyWhoBurns in forum Newbie / General discussionsReplies: 3Last Post: 11th Dec 2010, 21:12 -
Burning mpg files
By batke in forum Newbie / General discussionsReplies: 3Last Post: 7th Jan 2009, 22:18 -
Burning a DL dvdr problem
By efiste2 in forum DVD RippingReplies: 3Last Post: 16th Jul 2008, 15:06 -
Is it safe to write on DVDR BEFORE burning?
By snowbound in forum Authoring (DVD)Replies: 6Last Post: 23rd Mar 2008, 20:29 -
burning a DVD from MPG files
By nick177th in forum Authoring (DVD)Replies: 2Last Post: 6th Sep 2007, 17:36
