Hi Major! Hi everybody!
Yesterday, i made a DVD from a DivX .AVI file, but i had had a little problem.
The source is a DivX NTSC (23.997 FPS). Duration : 101 minutes.
I chose the DVD Hi-bitrate preset, change the size to DVD 16:9, the framerate on PAL, put the duration and choose 1 DVD 4Gb. Then i clicked on the Best button to have the right bitrate.
In the Option tab, i chose Profile DVD, unchecked the SET 3:2, checked GOP headers and Letterbox (So GOP, No SVCD scan, Letterbox, Altivec, Bicubic and Decode with Quicktime were check)
In the tools tab, i chose Author as DVD and chose Mux as... DVD, then i launched the encoding:
Here is the log file:
Encoding started on Sat Dec 27 18:13:00 CET 2003
INFO: [yuvscaler] yuvscaler (version 1.7.0) is a general scaling utility for yuv frames
INFO: [yuvscaler] (C) 2001-2002 Xavier Biquard <xbiquard@free.fr>
INFO: [yuvscaler] yuvscaler -h for help, or man yuvscaler
INFO: [yuvscaler] input: frame size: 720x576 pixels (622080 bytes)
INFO: [yuvscaler] input: frame rate: 25/1 fps (~25.000000)
INFO: [yuvscaler] input: interlace: none/progressive
INFO: [yuvscaler] input: sample aspect ratio: 1:1
INFO: [yuvscaler] from 720x576, take 720x576+0+0, NOT_INTERLACED/PROGRESSIVE
INFO: [yuvscaler] scale to 720x576, 720x576 being displayed, NOT_INTERLACED/PROGRESSIVE
INFO: [yuvscaler] Scaling uses the RESAMPLE algorithm,
INFO: [yuvscaler] without line switching
INFO: [yuvscaler] without time forwarding
INFO: [yuvscaler] Without luminance correction
INFO: [yuvscaler] Without chrominance correction
INFO: [yuvscaler] frame rate: 25.000 fps
INFO: [yuvscaler] Scaling ratio for width is 1 to 1
INFO: [yuvscaler] and is 1 to 1 for height
INFO: [yuvscaler] Specific downscaling routing number 4
INFO: [yuvscaler] output: frame size: 720x576 pixels (622080 bytes)
INFO: [yuvscaler] output: frame rate: 25/1 fps (~25.000000)
INFO: [yuvscaler] output: interlace: none/progressive
INFO: [yuvscaler] output: sample aspect ratio: 1:1
INFO: [mpeg2enc] Selecting DVD output profile
INFO: [mpeg2enc] Assuming norm PAL
INFO: [mpeg2enc] Encoding MPEG-2 video to /Volumes/Externe/VOB/nemo.m2v
INFO: [mpeg2enc] Horizontal size: 720 pel
INFO: [mpeg2enc] Vertical size: 576 pel
INFO: [mpeg2enc] Aspect ratio code: 3 = 16:9 display
INFO: [mpeg2enc] Frame rate code: 3 = 25.0 (PAL/SECAM VIDEO / converted FILM)
INFO: [mpeg2enc] Bitrate: 3746 KBit/s
INFO: [mpeg2enc] Quality factor: 3 (Quantisation = 3) (1=best, 31=worst)
INFO: [mpeg2enc] Field order for input: none/progressive
INFO: [mpeg2enc] New Sequence every 9999 Mbytes
INFO: [mpeg2enc] Assuming non-video stream of 246 Kbps
INFO: [mpeg2enc] Search radius: 16
INFO: [mpeg2enc] GOP SIZE RANGE 9 TO 15
INFO: [mpeg2enc] Setting colour/gamma parameters to "PAL B/G"
INFO: [mpeg2enc] Progressive format frames = 1
INFO: [mpeg2enc] Using default unmodified quantization matrices
INFO: [mpeg2enc] Buffering 39 frames
INFO: [mpeg2enc] SETTING AltiVec for QUANTIZER!
INFO: [mpeg2enc] SETTING AltiVec for MOTION!
INFO: [mpeg2enc] SETTING AltiVec for TRANSFORM!
INFO: [mpeg2enc] SETTING AltiVec for PREDICTION!
INFO: [yuvscaler] End of stream!
INFO: [yuvscaler] Normal exit: end of stream with frame number 150601!
INFO: [mpeg2enc] Guesstimated final muxed size = 2828937774
INFO: Opened WAV file, freq = 48000 Hz, channels = 2, bits = 16
INFO: format = 0x1, audio length = 1156575744 bytes
INFO: slots/frame = 672
INFO: frac SpF=0.000, tot bitrate=224 kbps, s freq=48.0 kHz
INFO: System is big endian
INFO: Avg slots/frame = inf; b/smp = inf; br = inf kbps
INFO: Encoding with psychoacoustic model 2 is finished
INFO: The MPEG encoded output file name is "/Volumes/Externe/VOB/nemo.mp2"
Next the mplex process:
INFO: [mplex] mplex version 2.2.2 ($Date: 2003/05/13 20:27:15 $)
INFO: [mplex] File /Volumes/Externe/VOB/nemo.m2v looks like an MPEG Video stream.
INFO: [mplex] File /Volumes/Externe/VOB/nemo.mp2 looks like an MPEG Audio stream.
INFO: [mplex] Video stream 0: profile 8 selected - ignoring non-standard options!
INFO: [mplex] Found 1 audio streams and 1 video streams
INFO: [mplex] Selecting dvdauthor DVD output profile
INFO: [mplex] Multiplexing video program stream!
INFO: [mplex] Scanning for header info: Video stream e0 (/Volumes/Externe/VOB/nemo.m2v)
INFO: [mplex] VIDEO STREAM: e0
INFO: [mplex] Frame width : 720
INFO: [mplex] Frame height : 576
INFO: [mplex] Aspect ratio : 16:9 display
INFO: [mplex] Picture rate : 25.000 frames/sec
INFO: [mplex] Bit rate : 3746000 bits/sec
INFO: [mplex] Vbv buffer size : 229376 bytes
INFO: [mplex] CSPF : 0
INFO: [mplex] Scanning for header info: Audio stream c0 (/Volumes/Externe/VOB/nemo.mp2)
INFO: [mplex] MPEG AUDIO STREAM: c0
INFO: [mplex] Audio version : 1.0
INFO: [mplex] Layer : 2
INFO: [mplex] CRC checksums : no
INFO: [mplex] Bit rate : 28672 bytes/sec (224 kbit/sec)
INFO: [mplex] Frequency : 48000 Hz
INFO: [mplex] Mode : 0 stereo
INFO: [mplex] Mode extension : 0
INFO: [mplex] Copyright bit : 0 no copyright
INFO: [mplex] Original/Copy : 0 copy
INFO: [mplex] Emphasis : 0 none
INFO: [mplex] SYSTEMS/PROGRAM stream:
INFO: [mplex] rough-guess multiplexed stream data rate : 4036248
INFO: [mplex] target data-rate specified : 10080000
INFO: [mplex] Setting specified specified data rate: 10080000
INFO: [mplex] Run-in Sectors = 89 Video delay = 13019 Audio delay = 16619
INFO: [mplex] New sequence commences...
INFO: [mplex] Video e0: buf= 237568 frame=000000 sector=00000000
INFO: [mplex] Audio c0: buf= 4096 frame=000000 sector=00000000
++ WARN: [mplex] File size exceeded before split-point in video stream
INFO: [mplex] Starting new output file...
**ERROR: [mplex] Need to split output but there appears to be no %d in the filename pattern /Volumes/Externe/VOB/nemo.mpg
Look at the last line. I checked my .mpg file, and discovered that the process stop near 2Gb.
So today i quit the application and relaunch ffmpegX. Go directly in the tools tab, choose my 2 files (.mp2 and .m2v), check Author as DVD and Mux as... DVD.
And it works:
INFO: [mplex] Scanned to end AU 150600
INFO: [mplex] STREAM e0 completed @ frame 150600.
INFO: [mplex] STREAM c0 completed @ frame 250991.
INFO: [mplex] Multiplex completion at SCR=542148754.
INFO: [mplex] Video e0: buf= 153788 frame=150600 sector=01310743
INFO: [mplex] Audio c0: buf= 1408 frame=250991 sector=00083499
INFO: [mplex] VIDEO_STATISTICS: e0
INFO: [mplex] Video Stream length: 2643698544 bytes
INFO: [mplex] Sequence headers: 10303
INFO: [mplex] Sequence ends : 1
INFO: [mplex] No. Pictures : 150600
INFO: [mplex] No. Groups : 10303
INFO: [mplex] No. I Frames : 10303 avg. size 32588 bytes
INFO: [mplex] No. P Frames : 40210 avg. size 21293 bytes
INFO: [mplex] No. B Frames : 100088 avg. size 14504 bytes
INFO: [mplex] Average bit-rate : 3510800 bits/sec
INFO: [mplex] Peak bit-rate : 4150000 bits/sec
INFO: [mplex] BUFFERING min 15 Buf max 134306
INFO: [mplex] AUDIO_STATISTICS: c0
INFO: [mplex] Audio stream length 168666624 bytes.
INFO: [mplex] Syncwords : 250992
INFO: [mplex] Frames : 250992 padded
INFO: [mplex] Frames : 0 unpadded
INFO: [mplex] BUFFERING min 15 Buf max 683
INFO: [mplex] MUX STATUS: no under-runs detected.
INFO: dvdauthor creating VTS
STAT: Picking VTS 01
STAT: Processing /Volumes/Externe/VOB/nemo.mpg...
STAT: VOBU 16 at 3MB, 1 PGCS, 0:00:08
STAT: VOBU 32 at 7MB, 1 PGCS, 0:00:17
STAT: VOBU 48 at 10MB, 1 PGCS, 0:00:27
STAT: VOBU 64 at 13MB, 1 PGCS, 0:00:36
STAT: VOBU 80 at 17MB, 1 PGCS, 0:00:46
STAT: VOBU 96 at 22MB, 1 PGCS, 0:00:55
STAT: VOBU 10256 at 2732MB, 1 PGCS, 1:39:56
STAT: VOBU 10272 at 2735MB, 1 PGCS, 1:40:05
STAT: VOBU 10288 at 2739MB, 1 PGCS, 1:40:15
STAT: VOBU 10303 at 2743MB, 1 PGCS, 1:40:24
INFO: Generating VTS with the following video attributes:
INFO: TV standard: pal
INFO: Aspect ratio: 16:9
INFO: Resolution: 720x576
INFO: Audio ch 0 format: mp2/2ch, 20bps
STAT: fixing VOBU at 3MB (17/10303, 0%)
STAT: fixing VOBU at 7MB (33/10303, 0%)
STAT: fixing VOBU at 10MB (49/10303, 0%)
STAT: fixing VOBU at 13MB (65/10303, 0%)
STAT: fixing VOBU at 17MB (81/10303, 0%)
STAT: fixing VOBU at 2732MB (10257/10303, 99%)
STAT: fixing VOBU at 2735MB (10273/10303, 99%)
STAT: fixing VOBU at 2739MB (10289/10303, 99%)
STAT: fixed 10303 VOBUS
INFO: dvdauthor creating table of contents
scanning /Volumes/Externe/VOB/nemo.mpg.DVD/VIDEO_TS/VTS_01_0.IFO
0.36% done, estimate finish Sun Dec 28 11:34:46 2003
0.71% done, estimate finish Sun Dec 28 11:34:46 2003
1.07% done, estimate finish Sun Dec 28 11:34:46 2003
1.42% done, estimate finish Sun Dec 28 11:34:46 2003
1.78% done, estimate finish Sun Dec 28 11:34:46 2003
99.29% done, estimate finish Sun Dec 28 11:33:53 2003
99.65% done, estimate finish Sun Dec 28 11:33:53 2003
Total translation table size: 0
Total rockridge attributes bytes: 0
Total directory bytes: 4096
Path table size(bytes): 42
Max brk space used 0
1404928 extents written (2744 Mb)
So, why i have had this error the first time:
PS: The DVD seems OK in Apple DVD player, no audio sync problems and i have a 25 FPS PAL movie now.
Thanks in advance!
Toche (ffmpegX 0.0.9a registered user)
Ti 867 MHz - 768 Mo - Airport - 10.3.4
ffmpegX 0.0.9m [REG]
No output: /bin/sh: -c: line 0: syntax error near unexpected token `('
By marmi in forum ffmpegX general discussionReplies: 4Last Post: 16th Jan 2011, 09:14 -
trying to convert AVI to DVD. mplex error. Cannot find .mpa file?
By anarchyx34 in forum ffmpegX general discussionReplies: 8Last Post: 14th Sep 2008, 19:14 -
How do I split and capture the video on the DVI output on MacBook Pro?
By kmxe in forum Newbie / General discussionsReplies: 6Last Post: 18th Jul 2008, 20:49 -
AVI split/screen output
By cinnamontea in forum Newbie / General discussionsReplies: 2Last Post: 31st May 2008, 22:08 -
svcdvd problem, mplex error
By randomtool in forum ffmpegX general discussionReplies: 1Last Post: 26th Sep 2007, 10:49
