Can i edit ONLY selected frames on VDUB?
I dont want edit ALL the movie.
I'd like select frames and add a filter to edit only them.
if it is not possible on VDUB ,which is other program could i use?
thx in advanced.
There is a Conditional Filter for Vdub that runs other
filters on selected frames only. -
Originally Posted by FOO
Conditional Filter ?
do you know where Can I get?
thx ,again. -
A quick Google search found the following:
Conditional FilterHello.
simple photoshop edits to selected frames (photoshopping time code away)
By Spiny Norman in forum EditingReplies: 8Last Post: 27th Jul 2011, 12:57 -
How do you blur selected frames in AVIsynth?
By Nagashi in forum EditingReplies: 4Last Post: 9th Jan 2011, 19:30 -
Edit Avi: VDub / VDubMod / Nandub
By Rinsin in forum EditingReplies: 11Last Post: 1st Mar 2010, 17:33 -
VDub, Key frames and syncing...
By takearushfan in forum Newbie / General discussionsReplies: 4Last Post: 16th Feb 2010, 14:04 -
Hauppage WinTV, BTWinCap to Vdub, dropping frames
By elvisish in forum Capturing and VCRReplies: 0Last Post: 4th Aug 2008, 11:03
