    Jan 2003
    Napoli, Italy
    I've captured an Huffyuv AVI with my capture card (PCM Audio 44.1Khz 16 bit Stereo) and using VirtualDUB. Now I need to cut something. Two questions :
    1 - Work for Video and Audio is to be set at Direct Copy Stream ? (I will compress later)
    2 - Since the file is sized almost 50GB I haven't got disk space to make a copy. Can I cut it and then save by overwriting existing file ?
    Emanuele
    webmaster - http://www.paolacardullo.net
  2. Member housepig's Avatar
    Jan 2003
    the Plains of Leng
    1. yes.
    2. no.
    - housepig
    Housepig Records
    out now:
    Various Artists "Six Doors"
    Unicorn "Playing With Light"
  3. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    RE #2:
    If you're converting to mpeg then I suggest frameserving. No filesaving required, look it up in the guides.
