  1. does anybody know how to convert swf flash movies to mpeg?
    i can do so, but i can not get any sound out of the final result. so, i would need to extract the audio somehow. quicktime can't do this, and neither can EO Video.
    does anybody know how to work with this?
    asdf
  2. Hmm. I am missing the answer...
    I want to do the same as you so I can archive flash animations to AVI/MPG movie files.
    Check this user guide for some more info...
    www.dvdrhelp.com/forum/userguides/105332.php
    ...and search these forums in the "howto" category also.
    Good luck to you!
  3. Use Magic Swf2Avi to convert!
    Magic Swf2Avi is a professional tool that can convert swf to avi which can be downloaded from http://www.effectmatrix.com/swf2gif
    If you want to convert to mpeg, TMpgEnc can be used.
  4. I have downloaded Magic SWF2AVI and it seems like an ok program...
    but, for some flash movies, i have a problem with this process.
    The audio seems to be made up of several mp3 files. so when i extract, i get as many as 10 different files. one is the main audio, and the rest is just small sounds that come in once in a while during the movie.
    Other than editing these together myself (which i dont really know how to do) is there any other way to get the extracted audio to be only one file?
    asdf
  5. you can use WinADR to capture the sound just like you hear it from your speakers. then you have to trim it and manually sync it to the video but at least its all together as it should be. Its easier than trying to put the audio together piece by piece.
