I tried doing a forum search to answer my questions but it's hard constructing a solution from 77 relevant bits and pieces.
My questions are simple:
If I cut videos on fcp, can I use Toast 6.0 to burn a DVD?
Or would I have to export my video from fcp as a Quicktime movie?
Toast can apparently burn a DVD longer than one hour,
but can it handle a video that's 2.5 hours long?
Would it look absolutely terrible?
Thank you for any two cents.
MattC
Matt Cramer
I'm not exactly sure how Toast encodes Quicktime files, but my guess is that they might look bad. It depends on what you're going for. If you need to produce professional results that you are under contract for, I wouldn't do it, but if its just to backup some footage that you're not planning on giving people, go for it.
Otherwise I'd reccommend using Apple's Compressor or Bitvice, and then using DVD2One to shrink it to one dvdr. That's what I do for all projects that exceed 2 hours 10 minutes or so. The compression is done frame by frame, and is much better quality--you can use it and get professional results. -
Thanks Travtufts.
What is Apple's Compressor and Bitvice? I didn't realize Apple had a compressor. Are these both software programs you're referring to?
MattMatt Cramer -
yes.they are both software encoders,i believe both will do a good job,some prefer one or the other.
Best Setting for HD in FCP to Get Smooth Videos on Youtube and Vimmeo
By ofpeb in forum MacReplies: 2Last Post: 10th Jan 2012, 15:02 -
FCP: What is the best way to work with .m2v files in a FCP timeline?
By murraymile in forum MacReplies: 1Last Post: 23rd Jan 2009, 16:59 -
Hours of Music without Hours of Video Data in DVD Architect
By Guff22 in forum Authoring (DVD)Replies: 3Last Post: 6th Aug 2008, 22:23 -
Slow Mo on FCP
By James in HD in forum MacReplies: 4Last Post: 2nd Dec 2007, 22:33 -
NO Audio in FCP ???
By willndmb in forum MacReplies: 3Last Post: 22nd May 2007, 13:33
