When I put my video into Ulead to author the widescreen is smushed (or cut off edges) into a regular TV dimensions. How do I make it stay as a widescreen video?
Check the do not convert compliant MPEG files check box
Also check aspect ratio setting in your playback software/device -
okay, did that.... but it cuts off the edges... id like to retain the to and bottom bars. I see a keep aspect ration box, but i cannot select it.
im playing it back in ULEAD.. -
Don't bother with what you see in ULead-afterencoding it should play correctly. Create the DVD files on PC and check with a software player before burning.
Checked with software and it wasnt wide screen
Anyone out there familiar enough with the program to help me? -
My version says SE
I do not think that this is limiting my widescreen capabilities though.
any ideas yet?
alternative to ulead movie factory
By marlo in forum Newbie / General discussionsReplies: 1Last Post: 15th Sep 2008, 03:48 -
Problems with Ulead Movie Factory
By merkuria_lyn in forum Authoring (DVD)Replies: 4Last Post: 25th Oct 2007, 13:12 -
Ulead Movie Factory 6 plus
By ictaylor in forum Newbie / General discussionsReplies: 1Last Post: 10th Jul 2007, 02:20 -
Ulead DVD Movie Factory
By koberulz in forum Newbie / General discussionsReplies: 10Last Post: 26th Jun 2007, 07:14 -
Ulead DVD Movie Factory 5 Plus Help
By sootylfc in forum Authoring (DVD)Replies: 3Last Post: 21st May 2007, 18:20
