The mpg that I need for a vcd is one minute too long. Is there any way to speed up the video of the mpeg or the avi it came from so that it is one minute shorter? I already cut it to pieces, so no more cutting.
The only way to make it smaller is to use a lower bitrate (for either the audio or video) when you create it. You could demultiplex the audio and video, discard the audio, redo the audio at a lower bitrate, multiplex the A and V back together. Up to you, it might be easier to just redo the whole thing if you're not familiar.
If it's just 1 minute over (what's that in MB?) you could just try overburning, you should be able to go to 810 MB or so (maybe)."Art is making something out of nothing and selling it." - Frank Zappa
Looking for best way to make a time compression
By Jonz in forum EditingReplies: 11Last Post: 3rd Oct 2011, 17:51 -
First time caller - Captured analogue video - compression issues
By foggys916 in forum Capturing and VCRReplies: 4Last Post: 19th Sep 2011, 06:33 -
Jpeg compression taking much time
By mourya in forum ProgrammingReplies: 0Last Post: 18th Jan 2009, 17:47 -
DVD -> AVI -- reversing time compression (pref. wth VirtualDub)
By Calidore in forum Newbie / General discussionsReplies: 0Last Post: 20th Oct 2008, 15:22 -
Problem Using Vider Studio 10 - Start Time After End Time
By jmsrickland in forum Newbie / General discussionsReplies: 0Last Post: 31st Jul 2008, 18:48
