I update to 1.0.1 ver. but when I try to make disk or folder always popup window aplication has to be close.Error Report.
Anybody has problem with that or somebody can help me???![]()
Thanks![]()
No, I don't.
You have to be more specific
1. Does this error occur only with one project or every, even simple, made from scratch in 1.01?
2. How much space do you have on your hard disks?
3. Are all your files DVD compliant or the program transcodes them?
Try reinstalling Adobe, after uninstall - delete the program directory and registry entries, reboot and then install Adobe 1, and then upgrade it to 1.01 and see what happens.Arek -
On drive C where is Encore and my project is 11Gb free.
This problem is with every video files when I try to transcod them. -
Transcode the video streams at least to elementary MPEG2 streams first before importing them into Encore. I don't particularly like the encoder that Encore uses so I use TMPGEnc to encode to m2v files before importing into a DVD project. TMPGEnc also allows you a lot more flexibility in the way you choose to encode your video files. At least this way you won't have to worry about transcoding the video stream during the build process.
encore dvd adobe cs5
By donnaglait in forum Authoring (DVD)Replies: 2Last Post: 26th Aug 2011, 06:30 -
Problem importing Russian subtitles into Adobe Encore
By adanepst1 in forum SubtitleReplies: 2Last Post: 29th Jan 2009, 13:12 -
Need an Adobe Encore DVD Guru for this one....
By sdsumike619 in forum Authoring (DVD)Replies: 2Last Post: 9th May 2008, 19:24 -
Problem in Adobe Encore DVD
By zombie_chan in forum Authoring (DVD)Replies: 10Last Post: 24th Apr 2008, 00:09 -
Adobe Encore 2.0 DVD Menu
By ozab in forum Authoring (DVD)Replies: 0Last Post: 13th Aug 2007, 16:03
