Im finding it extreamly difficult to find a way \ program that can convert .asf files to (hopefully in the end..) a VCD MPG. Something to do with microsoft wanting to disable peoples ability and freedom to covert their files?? a fear i might put my ''he-man masters of the universe'' cartoon on a VCD for my little sister for Xmas!!?? PLEASE if anyone knows how to ASF->MPG or AVIetc please reply here!!
thanx!!![]()
<font size=-1>[ This Message was edited by: ENGLISH on 2001-10-15 15:23:53 ]</font>
First get ASF Tools from the tool section on this site. Run your .asf file thru the ASFTools repair feature (as most .asf files are slightly corrupted). Now, if your asf file is really asf, get VirtualDub1.3c and the patch available here also, and open the repaired file, select direct stream copy for both video and audio and save it as an avi. (if you got an error cannot find wmv1 decompressor, your file is really an .wmv not an .asf file.) Thats ok though, cause TMPGENC (available here also) will convert it directly to mpg, although a slower process.
Argh, sorry, TMPGEnc doesn't convert .wmv files very well at all, it freezes after about 6% done most of the time. If it did it, alot of the people here including myself that asked this same question, wouldn't be asking it
Thanx 4 ya help guys, the info solved 80% of my dificulties! thats enough to satisfy me for the moment
As it happens i discovered that some bright spark out there has alot of work to do - developing software \ de bugging software! However the programs availiable are fantastic never the less. Currently i have TMPGEnc telling me that its gonna take 45 hours to process a file 1hr20mins long - that must be my stupidity not TMPGEnc!!! Grrrrrr!!! -
45 hours? thats ridiculous. are you using the noise reduction filter on MAX setting?
...nope, no noise reduction im only coverting a repaired asf to mpg (vcd format) in TMPGEnc. The conversion stoped after 12 hours(!) so i am trying again, this time i have cliped the asf file in TMPGEnc to remove some file size... still gonna take 45hrs!! (bear in mind i have a 700m\herz P3 computer!) I would recomend that if this happens to anyone else use the ASF tools as above to chop up ya ASF file and do a little by litte.(i cant cos my file must be too corrupted or something to allow it to process). Ah well thanx for the input every 1, ill let u know if it finaly works this time... about 2 days from now!!
asf to MPG conversion
By kshavo in forum Video ConversionReplies: 1Last Post: 15th Oct 2010, 05:14 -
ASF to AVI
By Arizona42 in forum Video ConversionReplies: 1Last Post: 1st Sep 2008, 00:20 -
converting asf to avi
By projecttemp in forum Video ConversionReplies: 2Last Post: 3rd Aug 2008, 09:40 -
AVI to asf ?
By rindless in forum Portable VideoReplies: 38Last Post: 26th Jun 2007, 10:15 -
TMPGEnc Error converting asf to MPG-2
By Caned_and_Able in forum Video ConversionReplies: 7Last Post: 6th Jun 2007, 11:07
