  1. Hi all
    When I get this message authoring, how can I correct it?
    The files have been processed with SVCD2DVD
    "The video sequence header is incorrect.
    A video sequence header is necessary for every GOP in a standard DVD"
    Any suggestions?
  2. I think that the SVCD Mpegs would have an SVCD Header... So it'd need to be changed into a normal Mpeg-2 System header...
  3. Ok thanks, but how do I do this ?
  4. TMPGEnc's mpeg tools has a multiplexer where you can set the system type, for Mpeg-2 it has Mpeg-2 VBR System, and SVCD System, just re-multiplex it as a normal Mpeg-2 System.
