I'm download fast and the furious right now. But I didn't know that it was an .avi file. So, since I'm almost done, i want to know how to convert it to a .mpg file. I don't want to use VirtualDub. Is there an easier way?
Results 1 to 28 of 28
In the "how to" Guide on this website you'll find quite a few ways to convert your avi to mpg. Just choose before if you are making an mpeg1 or mpeg2.
I'm sorta a newbie. I don't know what's the difference with mpeg1 or mpeg2. Tell me what you prefer for a VCD.
For a standard VCD you will always need mpeg1. SVCD use the mpeg2 format.
Okay, I want to make a standard VCD mpeg1. But will you tell me where in the "how-to" section I can find the help? Or can you give me the URL to the page?
You will need this Guide:
http://www.vcdhelp.com/convert.htm
most software is downloadable from the tools section of the same website. -
okay..i'm still confused. can you get me straight to the program to do this converting. I don't know which link to go to.
http://www.vcdhelp.com/vcdtools.htm
Look for ENCODER, one of the best is TMPGEnc, it is free and most peoples of the forum use it, so you'll ever find one, when you have a question.
I suggest that you read the guide carefully. Don't expect that you can figure out that stuff in few minutes. Feel free to ask again.
<font size=-1>[ This Message was edited by: Truman on 2001-07-10 17:22:12 ]</font> -
I think the easiest will be to use TMPGEnc. Download the program TMPGEnc and the VFAPI plugin - install both and start.
You will be using a template called VCD Template - if you're in the US (VCD NTSC template should be used).
Better still print the guide out and do it step for step. -
@TRUMAN
We must stop meeting like this...people will start talking <grin> -
where do i get the VFAPI plug-in. i allready have TMPEnc. I know how to rip dvd.
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
You'll get the VFAPI plugin at the same site where you got the TMPGEnc program. I thought you were going to convert an avi to mpg? What has ripping a DVD got to do with this now? Can't quite follow you. -
my bad, that was a mistake. i'm done downloading it :VFAPI. what site give be directions and where?
Well, nowon is replying to my post, so I'll write here. I have the same problem weelblur(I wonder where you got yours
). If your read in my post, I can't get a VCD to work, I am using EZ CD Creator 5 Platinum. It says the System Clock Reference won't work with a VCD player. The System Clock Reference is 1230, but I have no idea how to change it. I burnt it anyway and it didn't work with my Standalone DVD. I really want to watch it in my living room, not my cheap computer chair that is as comfortable as looking at a VW Bug(not good)
Please help! -
where do i get the directions after i have downloaded the 2 programs?
and torker, i don't use ez cd creator. i only use that to duplicate my CDs. use nero -
@weeblur
Go to
http://www.vcdhelp.com/tmpgenc.htm
print out the page and follow it step by step -
@Torker
Where does it say "system clock ..." on your PC? If yes using which program? -
i'm gonna go try it laterz, when i'm done downloading it. my computer is so slow so it's gonna have ta wait. 56K
I'm going to come back here when i first test it out.
thanks guys
EZ CD Creator 5, it says it won't play. I'm pretty sure I did everything right. It's a DIVX avi. What quality should I use, and should I put it in VCD(NTSC)?
<font size=-1>[ This Message was edited by: Torker on 2001-07-10 18:31:38 ]</font> -
How should I output the file, in .dat? I was reading about a VCD, and it said it was in .dat format.
@TORKER
As I don't have EZ CD Creator I have no idea how the software works. Am I right in thinking that yuo want to make something play on your standalone DVD player and you have a DIVX avi file? -
OK have found your original posting and I think its better if we "move" there
Umm, thank for answering this problem of mine. But can you go here : http://www.vcdhelp.com/phpBB/viewtopic.php?topic=50067&forum=3&0
and answer that question? I'm really confused of why it don't work. -
Continue this topic here: http://www.vcdhelp.com/phpBB/viewtopic.php?topic=50117&forum=3&0
Can't convert avi to an avi that the my divx player will read.
By aarelovich in forum Video ConversionReplies: 5Last Post: 4th Feb 2010, 05:19 -
I get ac3, mpg, mpg.s.mpg, .xml & .mpv instead of VIDEO_TS/DVD
By emanmb in forum ffmpegX general discussionReplies: 5Last Post: 18th Apr 2008, 14:48 -
Trouble with AVI to DVD... please, read on...
By takearushfan in forum Newbie / General discussionsReplies: 17Last Post: 15th Apr 2008, 19:01 -
Captured audio from .mpg file can't be seen/read by many programs!
By omnikai in forum AudioReplies: 4Last Post: 16th Sep 2007, 14:09 -
MKV to avi cracked?.....read in....
By oldpainlessuk in forum Video ConversionReplies: 12Last Post: 21st Jun 2007, 01:36
