Hi!
I just got a new hard drive for Christmas-a Maxtor 160GB Ultra ATA/133.
I have just put it in (As a slave) then installed the software that came with the drive-but when I check the space on the new drive it only detects 31.4 GB? I also checked the BIOS and it is set to Auto..
Is there anyone out there familar with this sort of problem and can tell me how I can get it to recognize the full 160GB.....?
Thanks for your time!!
A bit more info is needed.
Like what o/s are you using? how old is your system, motherboard etc ?
Sounds a lot liike you havent formated the whole disk and have only created one partition of 31.4 gig.
If you are running XP then...
Start/Control Panel/Administtrative Tools/Computer Management/Disk Magement...
Will bring up a list of your drives and you will be able to format the rest of the drive from there. Or even delete the partition and start again.Not bothered by small problems...
Spend a night alone with a mosquito
Unable to power on the PC after adding 2nd hard drive
By alegator in forum ComputerReplies: 10Last Post: 3rd Apr 2010, 12:57 -
Sony Vaio with partitioned hard drive(Want full hard drive space on C)
By neworldman in forum ComputerReplies: 11Last Post: 17th Mar 2010, 13:42 -
Adding external hard drive
By didikai in forum Newbie / General discussionsReplies: 22Last Post: 14th May 2008, 02:07 -
By didikai in forum Newbie / General discussionsReplies: 2Last Post: 2nd Mar 2008, 22:05 -
Want some advice about adding a new hard drive
By videocheez in forum ComputerReplies: 19Last Post: 6th Jun 2007, 14:25
