I have two Divx video clips with VBR MP3 audio. I have been trying for two weeks to get either one to an authoring stage to make a vob file I can burn to DVD. I have done the following:
Per advice used Virtualdub to extract VBR MP3 to wav
Used headAC3he to convert wav to mp2
Used TMPGEnc Plus to encode DIVX video to MPEG 2 using the following guides more than once.
https://www.videohelp.com/forum/userguides/186739.php
http://dvd-hq.info/Compression.html
Used bitrate caculator for the 1:33:34 video length (Cal.bitrate 6322)
Using TMPGE to encode in ES (video only) my 96:34 M:S file is 484:24 M:S and it has video for the first 96:34 and the remaining 387:50 shows the final frame of the first 96:34. The size is 8.50GB instead of the 4.37GB it should be. It has taken anywhere from 7 to 11 hours to encode depending which guide I am using. I have even tried using TMPGE to simple multiplex these length mismatched m2v and mp2. I get a video that is jerky and audio that is garbled. Once I started encoding using the latter of the above guides and when the estimated time popped up 45 hours I aborted. Help needed Thanks Foz![]()
Results 1 to 1 of 1
Foz the newbie
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 02:41 -
tmpgenc 2.5 plus problem
By DSLGuy in forum Video ConversionReplies: 1Last Post: 3rd Apr 2008, 14:38 -
Problem with TMPGEnc
By The Monkees in forum Video ConversionReplies: 2Last Post: 1st Nov 2007, 15:58 -
TMPGEnc Problem
By djkevyb in forum Newbie / General discussionsReplies: 3Last Post: 27th Sep 2007, 15:46 -
TMPGEnc Problem !!!!!!!!!!!!!
By homantam in forum Newbie / General discussionsReplies: 2Last Post: 10th Sep 2007, 17:56
