I burned my first dvd and there is only one chapter. I have read the guides on how to do it but i am still confused. Can someone tell me what to do? Thanks!
When you add a mpg file to a new or existing project a sub screen will pop out with 2 tabs on it with clip information and chapter cut edit,click on the chapter cut edit and you will see a scroll bar that is your movie play time,grab the little marker at the beginning of the bar and move it to the desired time in the movie you want and click on add current frame to chapter,you can then drag the marker to another frame and repeat this up to 99 times for a total of 99 different chapters.
Problems with chapters in DVD authoring/audio temporarily off-sync
By nocomments87 in forum Authoring (DVD)Replies: 7Last Post: 9th Nov 2011, 08:44 -
DVD Chapters messed up after authoring
By dexter30 in forum Authoring (DVD)Replies: 13Last Post: 25th Mar 2011, 18:12 -
Which dvd authoring program could I use...
By sagat93 in forum Authoring (DVD)Replies: 5Last Post: 14th Oct 2009, 21:43 -
Can't have more than 24 chapters on TMPGEnc DVD Authoring?
By aqualung2003 in forum Authoring (DVD)Replies: 19Last Post: 5th Jan 2008, 14:41 -
Adding chapters in TMPGEnc DVD Author 3 with DivX Authoring?
By T_virus in forum Authoring (DVD)Replies: 3Last Post: 30th Dec 2007, 19:53
