I was thinking of the ATI AIW Pro. Is this a good card? From my understanding it can do real time MPEG2 compression, but I would also like to do SVCD in real time, but I'm not sure this board can do that.
I would like to record TV shows, edit out the commercials and then save it onto SVCD.
I use an ATI AIW Radeon. I have been happy with it. It should be noted that, while it does support real-time MPEG and MPEG-2 captures, it does not have a hardware encoder on it. I have a 1Ghz PIII and it eats well over half of my CPU during captures.
I capture at 7.5K, MPEG-1 I-Frames at 640x480 and encode to VCD with TMPGEnc. This method works well for me and I do not have any frame loss or sync problems. However, if I try to do my initial capture using standard MPEG (instead of I-Frame only), I get considerable frame loss due to my CPU not being fast enough. While I am capturing, I have to leave the computer alone. I cannot be encoding in the background, even at low priority or I will get frame loss.
SolveigMM Video Splitter 3 Release. AVC/264, MOV, MKV, MP4 on board
By DmitryV in forum Latest Video NewsReplies: 0Last Post: 1st Feb 2012, 11:42 -
video capture problems - HV20 camcorder is controlled but no video capture
By chebowitz in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 14Last Post: 27th Feb 2010, 11:49 -
Does overclocking mess up on-board video ?
By SingSing in forum Newbie / General discussionsReplies: 5Last Post: 8th Aug 2009, 00:39 -
Good capture device for pci-e board?
By ingeborgdot in forum Capturing and VCRReplies: 36Last Post: 7th Nov 2008, 15:17 -
How do I overclock Intel 945G on-board video card?
By oleglelchuk in forum Newbie / General discussionsReplies: 10Last Post: 13th May 2008, 22:48
