I tried to convert a RMVB on TMPGEnc before and it worked but without Audio. Now that i have finally figured out how take the Audio from a RMVB file when i go back to TMPGEnc it wont open the RMVB file. please tell me, Why wont it?
now that i have re-installed real alternative it keeps giving me an error.
TMPGEnc caused an error in
REALMEDIASPLITTER.AX
TMPGEnc will now close
Someone please help!!!!!!!!!!!
Well, I stand corrected. I was able to convert a RMV file in TMPGenc, but only because I don't use any Real Network software. Instead I have the Real Alternative Directshow filter installed.
A couple of things I experienced while running a test encode:
1. TMPGenc opened my Real Video file no problem but produced an mpeg
without audio just like you found.
2. This was remedied by extracting the audio from the Real Video file and converting it to wav. This produced a 22050hz mono PCM file which I then converted to a 44100hz stereo wav. I then used that file and transcoded to mp2. Finally I just multiplexed with TMPGenc MPEG Tools.
By the way, thanks for bringing up this issue of yours, mynameis97rb. I've converted RM files before using EO Video but I was never happy with the results because it always spit out a choppy frame rate. Anyhow, hope you get things going with your conversion. -
The Video is good quality for something that was just converted from a RMVB file. Still i need HELP!!!!!!!
