Not sure which forum to post this on but here it goes...
I am attempting to place my SVCD files on a DVD disk. I have been reading about SVCD2DVD on this site. This program turns my SVCD's into actual DVD's.
What I would like to do is create a very large 4.7GB SVCD instead of an actual DVD. Is there a simple way to do this?
What you is use tmpgenc to put all your SVCD togetter to 1 big file but you need a NTFS disc cause FAT32 doesn't support files larger then 4 GB.What I would like to do is create a very large 4.7GB SVCD instead of an actual DVD. Is there a simple way to do this?
Another problem is that you DVD-player might nog play the file cause you can't burn it as SVCD on a DVD but only as data file so your DVD-player has to play mpg files. Check the dvd players section if your DVD-player does.Greatings,
Yf -
There is no such thing as a 4.7G SVCD, it does not exist.
The nearest you can get is SVCD on DVD video, which it seems you have already done. The main problem there is, it is not DVD compliant. So you never know how any particular player will handle it.
Realplayer files to another file format or dvd format
By vieya in forum Video ConversionReplies: 8Last Post: 25th Dec 2009, 13:12 -
Converting from Flash .flv format to iPod Compatible .mp4 format in ffmpegX
By bananasontoast in forum ffmpegX general discussionReplies: 1Last Post: 3rd Jan 2009, 10:15 -
Converting from DVD format to playable on MAC format...
By livvyramone in forum MacReplies: 2Last Post: 23rd Jul 2008, 09:21 -
digital cable = the new svcd format?
By mazinz in forum DVB / IPTVReplies: 38Last Post: 8th Jul 2008, 02:22 -
Convert Coreldraw file format(cpt) to some other format like tiff
By mysts in forum Off topicReplies: 0Last Post: 31st May 2007, 11:38
