Hi, I used smartripper to put the entire DVD, not just the movie, to my hard drive. Done this thousands of times.
Ok so, the vob I want to remove is VIDEO_TS.VOB it is 2 MB.
If I just remove it from the folder with the other vobs and bups, how do I edit the ifo file?
I know I need to use ifoedit(I guess), but just what am I to do?
I have read all that I can on vobs here---I tried using vobrator along with IFOEDIT but am still clueless!
Any help would be much appreciated or guide me in the right direction.
I will then use NeroExpress to burn.
Thanks,
danCER
Why exactly do you want to remove the VIDEO_TS.VOB? As you said- it's only 2 MB.
how to remove subtitles before burning to DVD
By ouiglz in forum SubtitleReplies: 7Last Post: 15th Mar 2014, 15:27 -
Best Program to Remove Audio from VOB and insert another Audio
By Zhuge Liang in forum Authoring (DVD)Replies: 1Last Post: 16th Feb 2012, 03:42 -
How Can I Remove the Subtitles from a .VOB File and a .AVI File?
By channelz28 in forum Newbie / General discussionsReplies: 3Last Post: 21st Nov 2011, 20:45 -
Confused! Confused! Confused! VCR to DVD; major question Toshiba Diomage SV
By CAnn12 in forum Capturing and VCRReplies: 0Last Post: 5th Feb 2011, 12:26 -
Add/remove sub idx to/from vob
By ystiang in forum SubtitleReplies: 6Last Post: 8th Jun 2010, 23:50
