    Dec 2002
    ok so i can use tmpgen to create a movie file or BMP file , i have selected the output file into TMPGEN Authour and when i select it i cannot hear the audio, im sure its my fault so id just like to go over it again!!! if i put bitmap picture file into tmpg and then i need to put an audio file in which type of audio should i put in!!! and what should the outpt file be so i can succesfully put it onto author???
  2. I have been wonering how to put audio into the menu myself, everytime I have tried it, it doesnt work...Is there guide to adding audio to menus with tmpgenc dvd author that someone could link us to? That would be a great help. Thankx
    Boy do I love my avatar!
    Redding, California
    Make a DVD compliant MPEG2 file with TMPGEnc using a BMP or video file and audio file. Choose the DVD template and encode.
    With DVD-Author, use it as the background image. Under "Menu display settings", choose the Motion menu tab and click "Use motion menu". Set the number of seconds to be played.
    Regards,
    Chas
