  1. anyone knows of any tools i could use to merge multiple wmv into one? thks in advance
  2. Member lacywest's Avatar
    Aug 2001
    California
    Intervideo WinDVD Creator 2 ... does a excellent job by my standards.
    In the past months with my $20 a month ... Adult Bouncer membership ... I downloaded several adult movies broke down into separate wmv videos.
    512x384 resolution ... 20 or more ... occupying about 800 megs ... 30 megs each. I open Intervideo WinDVD Creator 2 and import these wmv videos into the program.
    Move them to the bottom section and the toolbar buttons will become active ... choose export file and then choose what resolution you want ... DVD Compliant Mpg-2 is my usual choice ... with AC-3 audio.
    Final result can be a 6 gig [or smaller or larger] Mpg-2 DVD Compliant video ... suitable for TMPGEnc DVD Author.
    No problem ... audio/video is in sync. Works great.
    PM me if you have any other questions.
  3. Member lacywest's Avatar
    Aug 2001
    California
    Originally Posted by Milo
    AsfTools can merge / cut / repair wmf files :
    http://www.geocities.com/myasftools/
    Yeah uh huh ... VERY Excellent TOOL .... NOT !!!
    I've tried it ... used it ... been there ... done that ... moved on.
    Stick with my suggestion ... InterVideo WinDVD Creator 2 ... works
  4. Why not, but can WinDVD creator 2 write wmf files ?
    Because I guess that kababoom was asking for that... (?)
    I don't use asftools that much, but every times I need it, it did the job.
  5. Member lacywest's Avatar
    Aug 2001
    California
    Actually it does ... but
    the name of this site is ... dvdrhelp not ... wmvhelp
