Can someone tell me what this is? Do I increase or decrease I.e. go from 64 to 32 or lower or the other direction to 128 or higher? My first VCD worked i.e. burned the VCD and could see all my files using my DVD player/TV combination. Same data set subsequently and I'm getting "Write data failed; Writing failed - buffer under run? using generic-mmc @ either 2x or 4x. Help appreciated.
A buffer underrun is when the computer cannot supply the info fast enough to the writer. To fix this you want to decrease your burning speed and/or close all programs that would be slowing down your computer.
Run Like You Stole Something -
A couple of additional tips ...
1. Make sure your HDD and Burner are on separate IDE channels (or cables). It is preferred that the burner be Master on IDE2.
2. Make sure that ithe Burner is jumpered and setup in BIOS and Windows as a DMA or UDMA device. -
BMR Dad,
without more details I can only guess that perhaps
you are using VCDEasy to burn your vcd? If you have
a modern burner there is an option called "burnproof or justlink"
that when activated can prevent buffer underrun errors. There
is a check box to activate this in the VCDEasy options.
If you are using VCDEasy, then repost your question to
the VCDEasy forum and remember to include:
- name and speed of burner
- computer type & speed
- a step by step overview of what you did to get this error.
ffmpeg gives buffer underflow
By zkab in forum Video ConversionReplies: 2Last Post: 9th Aug 2010, 03:45 -
Help: ImgBurn Buffer Device @ 59%
By butt_crack in forum ComputerReplies: 2Last Post: 5th Feb 2010, 17:22 -
Buffer Device question:
By butt_crack in forum DVD RippingReplies: 1Last Post: 5th Feb 2010, 11:35 -
What is buffer size?
By dzsoul in forum Newbie / General discussionsReplies: 1Last Post: 6th Dec 2009, 09:04 -
chunktab buffer too small?
By 820am in forum ffmpegX general discussionReplies: 1Last Post: 21st Dec 2007, 12:57
