You may have noticed, that some movies have places with problems in them. My LOTR Two Towers has a problem on the first half of cd1 (when the hobbits are fighting gollumn), in a certain place, the video stops and then starts from the beginning. It used to be different, then in that place the picture just got all wierd for a sec and went on fine, but I installed the K-lite codec pack lately, 'cause the nimo codec pack codecs dont play all the movies I have. Since the video is in Xvid,I decided to installed the nimos Xvid codec (Nic's build), the same codec I had before and with what the movie dident restart. The problem continiued.
PS! After a while (after installing Nimos Xvid), when opening the file again, acourding to Divx G400, the movie is using the DivX codec?!?!
Has anyone had the same problem, does someone know how to fix it?!
Please reply!
Results 1 to 1 of 1
insane scientist
Problems with Movie maker saving to dv-avi
By jbitakis in forum Video ConversionReplies: 7Last Post: 15th Sep 2010, 09:19 -
BD Rebuilder Movie Only Problems!
By kings322 in forum Blu-ray RippingReplies: 18Last Post: 1st Jun 2010, 05:11 -
Cannot get trimmed a DV-AVI movie in MS Movie Maker
By askmaxim in forum EditingReplies: 0Last Post: 30th Dec 2008, 05:44 -
DV-AVI widescreen 16:9 movie from Windows Movie Maker.
By bagb in forum Newbie / General discussionsReplies: 19Last Post: 12th Nov 2007, 10:37 -
Problems with subtitles in movie
By Lythrana in forum Newbie / General discussionsReplies: 4Last Post: 8th Jun 2007, 15:27
