  1. ok ive backed up alot of movies but ive enver had this b4, using dvd shrink, instant copy and dvd dycrptor.
    this always happens on the same movie, on each ofthe mentioned programmes, it causes my pc to restart, yet other movies oive done this has never happend, nor doe sit happen now, only with this 1 movie.
  2. I don't know but if you use win xp and this movie causes the system to crash, win xp will reboot instead of showing you a blue screen...
    If you use win xp , enable blue screen or look in the event log.
    That a movie causes this problem is strange (It must be something else!)... Wich movie is it?
    (<-- btw: look under my nick; I have always been confused )
    10110101100111012011 <- The bug Bill doesn't talk about.
    Jul 2003
    Houston Texas
    Is this the same problem you were having in April?
    BTW What movie is it. and how did you rip it.
  4. Originally Posted by parsonsj
    hmm no, that was due to overclocking isses, i play games now and use tmpg no problem, also do other movies with no problems. this dvd is called Cage fight vol 1-3 ive tryed dycryting it to hdd first but still crashes under shrink and instantcopy, where can i find this log? winxp restarts when it crashes.
  5. i've had instances where i try to play a dvd with a subtitle and my computer reboots. try it again and it reboots. turned out it was an old version of windvd causing the problem. god i hate random reboots...
