I am having trouble with DVDLAB at the moment. Doing a motion video using the simple techqnique. I just end up with .VOB files noting else. What could be the problem?
Can you create a log with DVDLAB to see what the problem is?
Head over to http://www.mmbforums.com/index.php that is the site with the DVD-Lab support forums, lots of knowledgeable folks there who love to help.
Usually when you get a compile error, your elemental streams are not the same.
Remember that the Standard version of DVD-Lab only supports one VTS stream, so all your audio has to be the same format as well, all your video has to be the same format.
You need DVD-Lab Pro version if you want to mix formats.--
Will
DVDlab PRO : Motion menu, cells, missing button highlights !
By TheCap in forum Authoring (DVD)Replies: 18Last Post: 13th Jul 2011, 11:14 -
Motion Menus in DVDLab Pro question
By ArtOfLosingMFZB in forum Newbie / General discussionsReplies: 1Last Post: 8th Mar 2009, 16:47 -
Problem ripping a movie to avi with AutoGK, fast motion audio/video
By Mr. SoAndSo in forum DVD RippingReplies: 1Last Post: 7th Oct 2008, 11:57 -
problem with dvdlab pro2
By postie1392 in forum Newbie / General discussionsReplies: 10Last Post: 27th Sep 2007, 06:00 -
Problem with DVDlab and 16:9 motion menus
By sektionschef in forum Authoring (DVD)Replies: 3Last Post: 8th Aug 2007, 05:11
