Hi all
I`ve made shortcuts to my CD drives on my desktop but every time I try to use them they fails to work by reporting "shortcut not found" and tries to point me to something totally irrelevant.
The icons work fine in "my computer" so I know the drives are working OK.
Any suggestions plz.
PS: I`m using XP Home+SP1+all latest updates
__________________
You should try deleting the shortcuts and redo the links. It sounds like your computer has messed up the links to the drives. That should do the trick for you.
Thx for the suggestion but I`ve tried deleting and re-making the shortcuts and get the same problem everytime
Win7 - Switching Display Devices with keyboard shortcuts?
By andyxoxo in forum ComputerReplies: 5Last Post: 24th Jun 2011, 22:07 -
Keyboard shortcuts for rm video?
By kathorama in forum Newbie / General discussionsReplies: 4Last Post: 16th Dec 2010, 17:12 -
PowerDVD Shortcuts
By ocgw in forum Media Center PC / MediaCentersReplies: 0Last Post: 29th May 2009, 11:22 -
AC3 on m4v not working, 48KHz AAC not working, 44.1KHz does?!?!
By dmjerbear in forum AudioReplies: 14Last Post: 11th May 2008, 18:23 -
DV not working
By mainegate in forum ffmpegX general discussionReplies: 9Last Post: 23rd Aug 2007, 19:04
