  1. I got cdmage, but i don't know how to use it. how can i convert the .cif file made by i author into a .bin+.cue to burn with cdrwin??
    May 2001
    London, UK - Bonn, Germany
    I thought the GUI was pretty self explanatory... anyhow if you go to
    http://www.geocities.com/cdmage/
    you'll find various websites listed that give instructions, have Q&A etc.
  3. Will CDimage convert cue/bin to Adaptec cif? Their web site isn't clear on this point....
    May 2001
    Unfortunately not Kitty, it converts cif to mpeg though
  5. Member adam's Avatar
    Sep 2000
    Load your cif. Click file/save as. It will automatically be set to .cue.
    Type in a name to call it, a little box will pop up. Select mode2/2352 and hit ok. 30 seconds later you have your bin and cue.
  6. ok...i got the latest cdmage and i opened up a .cif file made by EZCD4....but when i go to the file menu all i get is new,open,exit. there is an option called save boot image but it is greyed out
  7. You'll need to download latest beta version from the above address. Only beta has the ability to save as bin/cue.
  8. thanks a lot everyone...i got the beta version and it works fine!!!
