  1. i am trying to convert a flash slide show (.swf file) into a .avi or .mpg that i can play as a movie. is there any way i can do this? i tried to convert to .avi with virtualdub but didn't work.
    any help is greatly appreciated, thanks in advance,
    nightscape
    nightscape
    Apr 2002
    The State of Frustration
    You may want to try CamStudio to capture the flash video to AVI as it is running.
    Hello.
  3. Member daamon's Avatar
    Melbourne, Oz
    Hi nightscape,
    IF You've got Adobe Premiere, you can get an SWF add-in for it that will allow you to import the .swf file into the timeline. You can then edit as usual and export to your chosen format.
    Downside is that Premiere costs, and takes some getting around...
    There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
    Carpe diem.
    If you're not living on the edge, you're taking up too much room.
  4. You can convert in flash mx itself...
    You just have to save your file, then file > export movie (Cntrl + Alt + Shift + S)> choose a file name > choose if you like to compree the movie.
  5. hi everyone, thanks for the help.
    have a great day,
    nightscape
    nightscape
  6. Magic Swf2Avi is better.
    Magic Swf2Avi is a professional tool that can convert swf to avi which can be downloaded from http://www.effectmatrix.com/swf2gif
    If you want to convert to mpeg, TMpgEnc can be used.
