I just Purchased a DVD and want to back it up. Do to the qualiy loss when using progams like DVDshrink I'm gonna do it the old fasion way. Reencode the video in CCE. But Iwant to keep my menu's and trailers.
Problem is that the trailers are not in a seperate file they are part of the last vob. This is what i would like to be able to do without splitting my resulting mpv file.
1.) Have the movie stop playing after the end credits or return to the main menu[instaed of continuing into the trailers.}
2.) From the menu be able to select the trailer you want to veiw,after which it returns you to the previous menu to make futher choices.
anyhelp would be appreciated
Let Me elabarote a little more, I have a single video stream that I'm turning into DVD. I want to add a scene selection that will play a specific point in the stream then return to the main menu. To my knowledge this can't be acomplished with DVDLab which I already own. Ideal anyone
Head over to the DVD-Lab forum http://www.mmbforums.com/ and search for posts from maa under the subject "Play All Option" he heas some trick he uses by editing the IFO file.
Will
Cutting video sections with Virtualdub without recompressing
By rantpolicy in forum EditingReplies: 11Last Post: 16th Apr 2012, 06:48 -
Recording MMS stream from a certain point?
By Kanadon in forum Video Streaming DownloadingReplies: 4Last Post: 3rd Jun 2010, 21:31 -
Either sections of my video tape are missing or my VCR keeps skipping bits?
By contactadam2002 in forum Capturing and VCRReplies: 3Last Post: 12th Dec 2009, 16:02 -
Can I crop in certain sections of video in Virtual Dub Mod
By blackskimask in forum EditingReplies: 15Last Post: 5th Aug 2009, 06:22 -
Setting Specific Subtitle Stream -On- by Default.
By GangstaRap in forum Authoring (DVD)Replies: 7Last Post: 16th Jan 2009, 19:50
