Hi, i'm not totally a newbie, but I've come across a teeny problem..
On SOME dvd to vcd conversions, the mpg file from Dvdx has perfect audio-video sync, yet when I burn it in Nero (or VcdEasy with chapters) the sync is out (about 1/4 to 1/2 second - you know, chinese kung fu movie style (LOL)).
This is on a stand alone player. The mpg on the hard drive is perfect. And it's not all movies, more like a very small number (1 in 10 maybe).
Any ideas?
Meeow! -
I'm not that familiar with your dvd software program. It could be causing the sync problems or your standalone player could be the problem. If the newly created vcd plays ok on your computer but not in your stand-alone player, it is more than likely the fault of your player. I had a similar problem with certain vcd's getting out of sync on my Apex 500D but never getting out of sync on my GE 1101. You can check the rating of your DVD Player on this site to see if your player is known to have any problems. Some DVD players are known for being able to play almost anything flawlessly (i.e. - Pioneer 333/343 or GE 1101) while others including some expensive major brands, will stutter or refuse to play your disks or as in your case allow the sound track to get out of sync.
GOOD LUCK!
no sound when playing mpg file
By hussains in forum Newbie / General discussionsReplies: 1Last Post: 31st Mar 2010, 04:59 -
(Sound Problem) Converting karaoke Vob file to mpg/ other video type cause.
By kiangtong in forum Video ConversionReplies: 1Last Post: 23rd Jan 2010, 04:45 -
Why does this mpg file doesn't play sound in my divx player?
By Stealth3si in forum Newbie / General discussionsReplies: 15Last Post: 5th Jul 2009, 20:00 -
editer shows 'no sound', mpg plays with sound
By oldvideote in forum EditingReplies: 3Last Post: 7th Jul 2007, 09:01 -
Spliting large mpg file into clips and saving each clip as a mpg file ?
By denise4gb in forum EditingReplies: 1Last Post: 6th May 2007, 18:52
