I would like to convert my old vhs tapes to some type of disc but would like to know the best way to go about this with my panasonic e50 dvd recorder.
Would it be better quality to record the vhs on dvd-r or record on dvd-ram, transfer it to computer and burn it to svcd? Or would there be any difference in quality at all? Is svcd recommended when transfering vhs to disc?
Results 1 to 12 of 12
Please wait a couple of days before you bump your topic(reply to it).
vhs should goto svcd if its very good quality or vcd if its just average quality.. if you want to author a long play dvd use 1/2d1 Cvd (similar to svcd but can be used in dvd authoring packages.
but the quality won't suffer or benefit if I put vhs on svcd or on dvd-r? It will just stay the same right? So it sounds like svcd is the way to go when transfering vhs to disc. Is this correct?
If your 'capture' system is a DVD recorder, why not just put them straight to DVDr using one of the longer recording times (4 hours on a DVDr).
I don't yet own a Standalone DVD recorder but I understand that when using the longer recording times they drop down to 1/2 D1 res to help maintain quality. This should be as good as SVCD.
If you record to DVD-RAM in High Quality mode, transfer to a PC and re-encode to SVCD, I doubt you would notice any improvement in quality over using a long record mode on the Panasonic.
Just making yourself a lot of work by the look of it. -
yes, but I have a lot more cd-rs than I have dvd-rs. Plus dvd-r costs a lot more and I would just like to use them when Im when Im not going from vhs to disc.
Originally Posted by fsuorange
Then use SVCD, it should be as good as a 1/2 D1 DVD -
Your argument is spurious. CDR's actually cost more than DVDR's on a per bit basis. High quality SVCD's run about 3-4 CDR's per movie. You can generally equate that to 1 DVDR so cost wise CDR's are slightly ahead. For VHS you would have 2 movies per DVDR so your better off with DVDR.
For VHS tapes go 1/2D1 (CVD) and you should be fine. 40-50 minutes per CDR should give you maximum quality.To Be, Or, Not To Be, That, Is The Gazorgan Plan -
Current prices for a Taiyo Yuden CD is $.28/100, TY DVD-R $1.68/100. Do the math, you'll spend $1.75 in CDs to achieve the same amount of space as one DVD-R.
[sarcastic]
But I can get cheap CDs,
well Princo DVD-Rs can be had for $.50/100, which is the same OEM as the cheap CD-Rs
[/sarcastic]
With your E50 encoding is real time, and close enough to idiot proof.
Looks like Gazorgan types faster than I do.
Confused! Confused! Confused! VCR to DVD; major question Toshiba Diomage SV
By CAnn12 in forum Capturing and VCRReplies: 0Last Post: 5th Feb 2011, 11:26 -
Confused about 1080p
By gauche in forum Newbie / General discussionsReplies: 4Last Post: 18th Jan 2009, 08:51 -
Still confused on upconverting
By glp103 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 5th Jan 2008, 16:42 -
resizing, I'm confused!!!
By nalooti in forum Video ConversionReplies: 5Last Post: 19th Nov 2007, 08:14
