I just bought an Avermedia PCI card that comes with neoDVD software. I had my first test captured video and requires some advise or help.
1. Using the neoDVD, the video displayed and mpg file is showing fuzzy or distortion at the bottom part of the video. Is there a way to fix this?
2. The mpg file captured by neoDVD can't be opened by TMPGEnc or the DVD Author. Does anybody have problems like me? Is there a workaround?
The neoDVD software works for me even if there are some negatives mentioned on this bundled software. I tried Ulead Movie factory and I have the same problems as above. I did try Intervideo WinDVD recorder but I can't make it work.
I tried some research on this site from how-to's and selected forums and can't seem to find a direct answer to my problem.
Tagarich
Results 1 to 1 of 1
captured some video
By the_man_one in forum Capturing and VCRReplies: 10Last Post: 19th Aug 2011, 05:42 -
captured video with hauppauge card... video looks blurry
By granturissimus in forum Capturing and VCRReplies: 4Last Post: 2nd Feb 2011, 07:43 -
Video Encoding, MeGui + AviSynth fuzzy picture
By shorto in forum Video ConversionReplies: 8Last Post: 21st Mar 2010, 19:07 -
Fuzzy Video using ADVC100
By BonnieW88 in forum Capturing and VCRReplies: 3Last Post: 16th Jun 2009, 02:17 -
Nokia N73 fuzzy lines on the video from Nero Digital
By fdonline in forum Portable VideoReplies: 1Last Post: 17th May 2008, 05:00
