I may have made a mistake, I installed nimo codec pack 8 to make sure i had all the codecs i needed. When i tried playing movies WMP kept crashin so I took some advice and uninstalled the codec pack. Later i tried to use TMPG2.5 wizard to convert an AVI to mpeg so that i could burn it to a VCD. It would only take the video part but would say that the audio was unacceptable. I there any solution to this?
Thanks for the help
TMPEG does not like mp3 or ac3 audio,both common in DIVX(avi) files.
If it's one of those you need to convert it to mp2 or wav. -
load the file into virtual dub, in the video menu check direct stream copy and in the audio menu full processing mode, the in the file menu save as avi, tmpgenc should now take it
Svcd2dvd stopped working
By H4MST3R in forum SVCD2DVD & VOB2MPGReplies: 7Last Post: 12th Apr 2011, 21:53 -
SVCD2DVD Stopped Working
By magic90 in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 28th Sep 2010, 07:07 -
HELP PLEASE URGENT "video audio codecHelper has stopped working"
By kidkool in forum Video ConversionReplies: 3Last Post: 1st Jun 2009, 09:54 -
MPG Audio Stopped Working
By briandill in forum AudioReplies: 1Last Post: 11th May 2008, 15:33 -
WMP stopped working?
By glowworm12 in forum ComputerReplies: 5Last Post: 22nd Feb 2008, 08:44
